Need to locate exactly where the temperature gauge wire is in the car
RUDY MONTEZ
  • 1984 CHEVROLET MONTE CARLO
  • 5.0L
  • V8
  • FWD
  • 130,000 MILES
I need to locate where the wire is for the temperature sensor gauge, so I can replace the temperature gauge in my 1984 chevy monte carlo
Do you
have the same problem?
Monday, July 13th, 2015 AT 6:22 PM
CARADIODOC
  • EXPERT
You're replacing the gauge on the dash or the sensor on the engine? If you're after the sending unit, there may be two sensors, one for the gauge and one for the Engine Computer. Both should be very close to where the upper radiator hose connects to the engine. The sensor for the computer will always have two wires in its connector. The sensor for the gauge will have just one wire.
Monday, July 13th, 2015 AT 6:55 PM
Recommended Guides
