Stereo wiring
CT_TAZ23
  • 2001 FORD F-150
Six cylinder two wheel drive automatic.
My deck has four wires; red, black, yellow, blue. I have all the speakers hooked up correctly but the deck only gets power if I twist the red and yellow wires together and and hook them to the black/pink wire on my truck (accessories). My problem is I cannot seem to find the battery constant wire. How to connect the deck properly?
Tuesday, May 4th, 2010 AT 4:49 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Here are the full radio wiring diagrams for each radio that came in that tuck and a guide to help you test the connections with a video of the radio being installed:
and
https://youtu.be/jF_sDSS0n7I
Tuesday, May 4th, 2010 AT 4:54 PM
CT_TAZ23
  • 6 POSTS
Thanks. That is the best diagram I have seen yet, but I still cannot find that battery constant. I even tested the remaining wires with a multi-meter with the key out and still no luck. So I was wondering if I could use a bit of heavier wire straight from the positive side of the battery back through the firewall?
Tuesday, May 4th, 2010 AT 9:54 PM
BLUELIGHTNIN6
  • 16,542 POSTS
So you do not have that color wire? Has the stock radio wire harness been cut before or something?
Tuesday, May 4th, 2010 AT 9:55 PM
CT_TAZ23
  • 6 POSTS
They are all there, but I can only find twelve volts coming from the black with pink stripe wire with the key on.
Tuesday, May 4th, 2010 AT 10:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Try hooking your yellow wire to the trucks cigar lighter. That should work. Your stock radio may not have been wired to remain on with key off.
Tuesday, May 4th, 2010 AT 10:09 PM
CT_TAZ23
  • 6 POSTS
Will I still have use of that lighter socket?
Tuesday, May 4th, 2010 AT 10:19 PM
CT_TAZ23
  • 6 POSTS
Yes, I could still check the the time on it and set the clock and my presets would remain.
Tuesday, May 4th, 2010 AT 10:21 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, just wondering because my truck does not work if I remove key.
Anyways, yes do not remove the wire from the lighter, just splice into it and the lighter will still work fine.
Tuesday, May 4th, 2010 AT 10:23 PM
CT_TAZ23
  • 6 POSTS
Thanks appreciate the help.
Tuesday, May 4th, 2010 AT 10:30 PM
HENRY DERUELLE
I have a 2001 F150 XLT super crew cab. Trying to find the ground wire for after market FM mp3 stereo. Diagram I found on line says the ground wire is black/light green but there are two wires that match the color. Do I wire both blacks for my ground wire on the radio?
Thursday, December 29th, 2016 AT 2:06 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,895 POSTS
Hey HENRY,
Yes, you can use either ground wire will work.
Please let us know happens so it will help others.
Best, Ken
Tuesday, January 3rd, 2017 AT 12:35 PM
STEVENBRNNN5
  • 1997 FORD F-150
  • 200,000 MILES
The colors are black/purple, green/black, black, black/green, blue/dark blue.
Tuesday, January 3rd, 2017 AT 12:37 PM (Merged)
Do you have the base radio or the premium sound radio?
KHLOW2008
  • 41,815 POSTS
Here is a schematic of the radio circuit. I cannot seem to find some of the colors you have indicated.
STEVENBRNNN5
What do you mean?
STEVENBRNNN5
I think that is what I needed. Never mind the previous reply. Thanks!
JAYTEAR
  • 1988 FORD F-150
  • 123,000 MILES
How do I properly hook up my new CD player?
WRENCHTECH
  • 20,757 POSTS
You go to the stereo supply store and buy the correct "plug and play" adapter cable. Do not hack up the wiring harness.
PAGE13
  • 1994 FORD F-150
  • 6 CYL
  • MANUAL
  • 56,343 MILES
Installed a dual XDM6350 radio using wire harnesses. If I hook up the radio illumination wire (solid orange) to constant power the radio works if lights are off. If I hook the wire to switched power, it only works when lights are on, tried every combination I can think of but cannot seem to get constant power no matter what. Also, when orange is hooked to the constant, I have no dash lights. Any suggestions?
KHLOW2008
  • 41,815 POSTS
Hi Page13,
Thank you for the donation.
What is your original radio specs, base or premium (with amplifier)?
From both types of radio wiring schematics, I am not able to find any solid orange wire.
Do you have the wiring schematics for the new radio that you have installed?
https://www.2carpros.com/forum/automotive_pictures/192750_RadioWiring94F150Fig57a_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_RadioWiring94F150Fig58a_1.jpg
