My engine is turning over for a little while before it starts
DEVELOPER7
  • EXPERT
  • 2002 FORD ESCAPE
  • 87,250 MILES
Hi I have a question about my car. It used to start right away when I hit the ignition, but now it turns over for a little bit before it fires up? I have around 60,000 miles if that helps. Is there something I can do to check it out?
Do you
have the same problem?
Monday, November 4th, 2013 AT 11:41 AM
HMAC300
  • EXPERT
This could be anything really if your check engine light is not on check your fuel pressure if it's low it may cause this as well as a fuel filter. Spark plugs may be a bit wider so it may not do like new plugs. If it started on one turn over and now takes 5 I really wouldnt' worry about it. The vehicle is 10 yrs old so they don't quite do like the newer ones.
Monday, November 4th, 2013 AT 12:03 PM
Recommended Guides
