Transmission not shifting properly and code P1725
FEMI SMF AKERELE
  • 2000 LEXUS RX 300
  • V6
  • 4WD
  • 206,300 MILES
My transmission doesn't shift to higher gear and drives sluggishly when check engine comes on. Note check engine shows after driving for 5 minutes.
I scanned and got a p1725 error, what can I do?
Sunday, September 13th, 2020 AT 6:31 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I've attached picture diagnostic steps below relating to the trouble code P1725 you provided. Hope this helps and thanks for using 2CarPros.
Sunday, September 13th, 2020 AT 2:23 PM
FEMI SMF AKERELE
  • 5 POSTS
Thanks, I would get back to you.
Sunday, September 13th, 2020 AT 2:46 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Yes, keep us updated and let us know if you have any further questions about this issue. Hope this helps and thanks again for using 2CarPros.
Danny-
Sunday, September 13th, 2020 AT 3:38 PM
FEMI SMF AKERELE
  • 5 POSTS
Hi, thanks. I removed the NT speed sensors and tested it's resistance it read 667 and 686 respectively, the voltages was extremely low. Is this a good sign? So I just cleaned it.
Saturday, September 19th, 2020 AT 8:26 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,878 POSTS
It sounds like the input shaft speed sensor is bad. Here is how you can replace it. Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Tuesday, September 22nd, 2020 AT 12:24 PM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, the resistance is within range. It seems you are having an issue with the ECM then. You can find them remanufactured online but I suggest to buy new. I can give you a part number but I would need your VIN - vehicle identification number to confirm proper part. Hope this helps and thanks again for using 2CarPros.
Danny-
Tuesday, September 22nd, 2020 AT 12:43 PM
FEMI SMF AKERELE
  • 5 POSTS
Hi, thanks Danny. I changed the NT sensor and all is well. I guess it was damaged a little. Thank you once again.
Wednesday, September 23rd, 2020 AT 9:32 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Glad you were able to resolve the issue. Hope you will use or site again in the future.
Danny-
Wednesday, September 23rd, 2020 AT 10:47 PM
FEMI SMF AKERELE
  • 5 POSTS
Sure, definitely.
Wednesday, September 23rd, 2020 AT 11:29 PM
SJC12345
  • 20 POSTS
  • 2001 LEXUS RX 300
  • 130,000 MILES
I had my alternator replaced now my truck is at 4rpm when I do 60mph, anyone can help me, is it possible that the alternator has anything too do with this, and why is the rpm at 4, feels like the trannie will not change gears feels like it's stuck in 3rd. Trannie is not oringianall had it replaced severall years ago. Has around 30k miles on it. Machanic claims I need a new computer now. Trust him just not a very good mechanic
Saturday, September 26th, 2020 AT 10:05 AM (Merged)
  • 52,797 POSTS
If he is not very good then why are you there as he may have made a mistake in the repair?
Have him go over all his work to see if he left any connectors off before assuming you have an internal issue
SJC12345
  • 20 POSTS
How do you know if anything is bad unless they make a mistake 2 x or more in my case that's what happened,
But the problem is still the same, not why I use the mechanic but why after he replaced the alternator my rpm are at 4 while doing 60mph. Please just looking for help
SJC12345
  • 20 POSTS
I'm reading there's a possibility that the alternator can be the issue, can anyone please help me with this as I'm at a loss and wanna resolve the issue, can anyone please help me
SJC12345
  • 20 POSTS
I brang the truck back too him and of cause he hooked up the computer and tells me now that it's the computer on the truck, I have too beleive that's not the issue, The car ran beutiful before the replaced alternator, The car is a 2001 lexus and has more sensor's then egine parts, I read that an alternator can mess with multiable parts, my suspsion is he put a cheap alternator and will not admit he messed up, Who likes too admit fault
  • 52,797 POSTS
If the new alt is bad and putting out ac voltage instead of dc voltage, then yes, it could cuse other issues but not shifting into overdrive would be 1 of many other issues.
Did he say there were any codes when he put it back on the scanner?
SJC12345
  • 20 POSTS
ASEMaster6371
You seem too have a great reputaion, I would and need your expertise, via phone or e-mail. I'm willing too pay but I really need someone who knows what there talking about. Can you help. As too there a severall issues I need too have answer too
  • 52,797 POSTS
Let me know how I can help you.
SJC12345
  • 20 POSTS
ASEMaster6371
I'm sorry I'm new too using this siteand not geting the hang of it, Yes he gave me a code of some sort but when I looked it up it said it meant that the car was being tested, keep in mind that the check eng light is on so its not giving me an ans, the check eng light is a whole other matter that I'm dealing with. But the light was on before That's when I relized he was not a good machanic, we where still dealing with that issue and being my sister uses the car she had him change the alternator, It seems the more he touches it the more I see he just guesses at the problems
All this, like I said He seems honest and was very fare in price, He worked on my Ford explorer and never had a problem with his work, I just beleive that the 2001 lexus is way out of his league
DELANN POUNTAIN
  • 2000 LEXUS RX 300
  • V6
  • 240,000 MILES
I was driving my car and the gears started slipping and then it would go passed 2nd gear and I had to drive in 1st gear as far as I could and then the car wouldn’t drive anymore. Now I can shift out of park and then it goes straight to neutral and doesn’t drive. I have had my transmission cooler replaced recently and when they did my gear shaft code was showing up. I checked the gear shaft from the inside of my car and it is intact and perfectly fine. I need help.
SJC12345
  • 20 POSTS
I don't have the code in front of me, as far as the eng light He changed the oxygen sensor, then I find out it has 3 so I brang the truck too someone else and they said it was bank 1 sensor he changed that and still the light is on, I put a new gas cap cleaned the MAF sensor and checked for cracked of leaky hoses myself, still light is on, I'm guessing It might be bank 2 sensor but mean while, Now I have too deal with this RPM before I resolve the egn light as I beleive the high RPM can kill the eng of the trasmission
