My car stars when he wants
MYNEGGER
  • 2011 NISSAN ALMERA
  • 76,000 MILES
I change the engine after the car began to fail in the ignition, it takes a lot to turn to discharge the battery, trying to boot, I have a code cps, I check the line from crank position sensor to the ECU and they are good, check engine timing, I check ignition switch and this good, but I found something when I start the car I can turn off and turn a thousand times and the car star good, but if I turn the key to off position and to wait a minute for the deactive the main relay fault returns
Do you
have the same problem?
Saturday, May 25th, 2013 AT 5:13 PM
KHLOW2008
  • EXPERT
Sortry, I could not understand your question.
Saturday, May 25th, 2013 AT 9:37 PM
Recommended Guides
