My 1994 Ford E150 5.8 liter engine hesitates
JESSE1961
  • 1994 FORD E-SERIES VAN
  • 150,000 MILES
I've been to 4 mechanics and had four diagnostic, all had somewhat different answers. None could fix my hesitations while driving problem. My mechanic had my van for a week, he got so upset he started buying parts to try and fix the hesitations well, he said to just buy a better engine to install.I've checked on-line for related issues and found many ford econolines with the same problems, I have to pickup my van with the same old hesitations. I'm asking, please can some great mechanic that had fixed this problem help. I replaced fuel tank, fuel pump, ecc replaced, all fuel injecters check out o.K, fuel filter replaced, map sensor, replace, distributor, rotor, cap, wires, smoke tested, O2 pressure sensor replaced, no codes. Please help may have to sale my new junk. Jesse,
Do you
have the same problem?
Monday, August 5th, 2013 AT 7:02 PM
  • EXPERT
Has anyone checked if for vacuum leaks?
Monday, August 5th, 2013 AT 8:27 PM
Recommended Guides
