The issues you're experiencing with your 2003 Chevrolet Tahoe could indeed be related to the fuel system, particularly the fuel pump or its components. Let's address each problem separately:
Issue 1: Starting Difficulty Below Half Tank:
This problem might be related to a weak fuel pump or a faulty fuel level sending unit. When the fuel level drops below a certain point (in your case, around half to a quarter tank), the fuel pump might struggle to maintain adequate pressure, causing starting difficulties. The fuel level sending unit is responsible for providing the fuel gauge with accurate information about the fuel level in the tank. If it's malfunctioning, it might not correctly indicate the fuel level, leading to starting issues. To address this problem, consider:
Check the fuel pump's performance and fuel pressure when the tank is below half. A weak fuel pump might need to be replaced.
Inspect the fuel level sending unit for accuracy and replace it if necessary.
Inspect and clean the fuel tank and fuel system for any debris that might be affecting the fuel flow.
Issue 2: Stalling and Hard Starting:
The stalling and hard starting problem could indeed be related to the fuel system as well, especially considering it happens more often with a lower fuel level. Here are some steps to troubleshoot and address this issue:
Check the fuel pressure when the issue occurs. A weak fuel pump might not be able to maintain sufficient pressure to keep the engine running properly.
Inspect the fuel filter and replace it if it's clogged. A restricted fuel filter can cause fuel flow issues.
Check for any vacuum leaks in the intake system that might be affecting the air-fuel mixture.
Inspect the ignition system components, such as spark plugs and ignition coils, for any signs of wear or malfunction.
Check for any stored trouble codes in the engine control module (ECM) using an OBD-II scanner. These codes might provide additional clues to the issue.
If you're on a tight budget and want to do some of the diagnosis and repairs yourself, start with checking the fuel pressure and inspecting the fuel filter. These are relatively straightforward tasks that can provide valuable information about the health of the fuel system.
SPONSORED LINKS
Friday, October 30th, 2015 AT 7:51 PM
