MANUAL TRANSMISSION will not shift into gear
3000GT1996
  • MITSUBISHI
Just have my clucth replace at the shop. Everyting work perfect, but after driven the car (1996 3000GT) for more then 5-10 miles, stop the car with engine still runnig, the gear in neutral. Right after that the gear will not shift into any gear no more. No into 1, 2, 3 or rev gear. Shut off the engine, the stick shift work perfect. Restart the engine, the gear will not shift. Restart the engine with gear in placed, the gear will not shift out and stuck at the same gear. Let the car cool down for several hours or over night, everything back to normal. It will drive and shift perfect, but after 10 miles driven. And after the car at complete stop, same problem repeat. At all time, the clutch padel pressure feel like normal. I brought the car back to the shop 3 times and they still did not fix or know what is wrong. Can somebody help.
Do you
have the same problem?
Sunday, January 15th, 2006 AT 11:31 AM
JACK42
Sounds like they bent the disc installing the trans
Thursday, February 9th, 2006 AT 5:56 PM
Recommended Guides
