Lights
MACE
  • MITSUBISHI
Hi, I have a mitsubishi magna advance 1998 model, My problem is when I brake my headlights come on aswell, dashlights also come on when I take my foot off the brake they go off again. On inspection of the battery I found one cell to be right down I topped it up when I started the car the next morning everything was working perfectly later that evening to come home from work the problem had re appeared, I subsequently replaced the battery the problem didnt go away. I recently jump started a motorists car for him approximately 3 days later the problem appeared could this have anything to do with the problem, no other problems evident runs perfectly fine all other electrics in good working order
Do you
have the same problem?
Thursday, March 1st, 2007 AT 2:09 AM
Check your main wiring harness
Wednesday, March 7th, 2007 AT 4:23 AM
Recommended Guides
