Where is the crank sensor located at on the 95 eclipse rs non turbo? Any help would be appreacited
Do you
have the same problem?
Thursday, March 22nd, 2012 AT 4:26 PM
KHLOW2008
MECHANIC
The crankshaft sensor is near the oil filter here is a guide to hep walk you through the steps of changing it with a diagram sbloe to show you the location on your car.
Image (Click to make bigger)
SPONSORED LINKS
Thursday, March 22nd, 2012 AT 5:08 PM
KRAZYKLINGER
MEMBER
1995 MITSUBISHI ECLIPSE
Electrical problem
1995 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual
Where is the location of the crankshaft position sensor on a 4g63t engine.
Thursday, February 28th, 2019 AT 3:20 PM
(Merged)
MECHANIC
Check above oil filter at front of engine
(Merged)
KRAZYKLINGER
MEMBER
Nope not there
(Merged)
MECHANIC
Turbo or Non also is it a 2.0 or 2.4
SPONSORED LINKS
(Merged)
KRAZYKLINGER
MEMBER
Its a 2.0 turbo
(Merged)
MECHANIC
Its on the left side of engine, by crankshaft end.
(Merged)
DANNY1991
MEMBER
1 POST
4 CYL
2WD
MANUAL
213,000 MILES
I got a 95 eclipse gs it will start for about 10 sec and die like u shut the key off but turn it off and try starting it again it will start and after a few times of doing that it will get to were it wont star and it wont get fire but if u let it set a little bit it will start right back up and do the same Ive replaced the ECU, camshaft sensor and the crankshaft sensor checked fuses and relays and the fuel pump so I cant find what is wrong with
it.
(Merged)
KHLOW2008
MECHANIC
Did you try to retrieve for troublde codes?
Was any repairs carried out prior to this occurring?
When it could not be started, did you test if sparks or fuel were missing?
(Merged)
MTHOMPSON
MEMBER
1 POST
1997 MITSUBISHI ECLIPSE
Engine Mechanical problem
1997 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual
were is the crankshaft sencor
(Merged)
JENKNIX
MEMBER
The crank shaft sensor is above the oil filter on the passenger side. It is held on by one bolt on the outside of the block. Just replaced mine.
