Crank Sensor
DRIFTKILLER101
  • 1995 MITSUBISHI ECLIPSE
Where is the crank sensor located at on the 95 eclipse rs non turbo? Any help would be appreacited
Thursday, March 22nd, 2012 AT 4:26 PM
KHLOW2008
  • 41,815 POSTS
The crankshaft sensor is near the oil filter here is a guide to hep walk you through the steps of changing it with a diagram sbloe to show you the location on your car.
Thursday, March 22nd, 2012 AT 5:08 PM
KRAZYKLINGER
Electrical problem
1995 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual
Where is the location of the crankshaft position sensor on a 4g63t engine.
Thursday, February 28th, 2019 AT 3:20 PM (Merged)
Check above oil filter at front of engine
KRAZYKLINGER
Nope not there
Turbo or Non also is it a 2.0 or 2.4
KRAZYKLINGER
Its a 2.0 turbo
Its on the left side of engine, by crankshaft end.
DANNY1991
  • 4 CYL
  • MANUAL
  • 213,000 MILES
I got a 95 eclipse gs it will start for about 10 sec and die like u shut the key off but turn it off and try starting it again it will start and after a few times of doing that it will get to were it wont star and it wont get fire but if u let it set a little bit it will start right back up and do the same Ive replaced the ECU, camshaft sensor and the crankshaft sensor checked fuses and relays and the fuel pump so I cant find what is wrong with
it.
KHLOW2008
  • 41,815 POSTS
Did you try to retrieve for troublde codes?
Was any repairs carried out prior to this occurring?
When it could not be started, did you test if sparks or fuel were missing?
MTHOMPSON
  • 1997 MITSUBISHI ECLIPSE
Engine Mechanical problem
1997 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual
were is the crankshaft sencor
JENKNIX
The crank shaft sensor is above the oil filter on the passenger side. It is held on by one bolt on the outside of the block. Just replaced mine.
