1993 Mitsubishi Eclipse overheating
TXTECHDAD
  • 1993 MITSUBISHI ECLIPSE
  • 4 CYL
  • FWD
  • MANUAL
  • 100,000 MILES
Afte starting car and traveling a few miles and the temperature needle has come to rest at it's normal position. It will go into the overheating area and then come back to it's normal position. It will do this several times before it finally stays at it's normal position. I have replaced the coolant sensor but it continues to do the same thing.
Do you
have the same problem?
Thursday, November 6th, 2008 AT 2:43 PM
Try replacing thermostat and go from there
Thursday, November 6th, 2008 AT 2:49 PM
Recommended Guides
