Misfire
SMIFFSON
  • 2003 HONDA CIVIC
  • 2.0L
  • 4 CYL
  • MANUAL
  • 101,600 MILES
My car is misfiring on all cylinders checked the usual plugs and coil packs (Civic type r ep3) my next thought was injectors. I happened to disconnect my IAT sensor and the misfire stopped, I have ordered a new one as it is only £30 but I am thinking it is not the part that is faulty and the misfire is going away due to the extra fuel the engine management is putting in with the IAT disconnected.
Do you
have the same problem?
Tuesday, May 30th, 2017 AT 1:57 AM
HMAC300
  • EXPERT
If the code is 0300 then it is a random misfire and may be low fuel pressure so check that as well as a vacuum leak like a broken hose/cracked/off etc. See link for fuel pressure.
Tuesday, May 30th, 2017 AT 5:44 AM
SMIFFSON
With the IAT sensor disconnected
Tuesday, May 30th, 2017 AT 2:27 PM
SMIFFSON
IAT connected
Tuesday, May 30th, 2017 AT 2:32 PM
HMAC300
  • EXPERT
Do a compression check and get back with results as well as fuel pressure like I asked the first time.
Tuesday, May 30th, 2017 AT 3:29 PM
Recommended Guides
