Fuel filter
GDOG812
  • 2002 MERCURY VILLAGER
  • 6 CYL
  • FWD
  • 122,000 MILES
Where is the fuel filter on a 2002 villager?
Thursday, August 18th, 2011 AT 2:07 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,889 POSTS
The fuel filter is located under the car near the rear. You must jack the car up, here is a guide to help you with that.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Here is a guide that will show you what you are in for when doing the repair.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Here is the location (below) diagrams for your car.
Cheers, Ken
Tuesday, July 25th, 2017 AT 4:36 PM
DARK_PHOENIX
  • 1994 MERCURY VILLAGER
1994 Mercury Villager 6 cyl
Trying to figure out where my fuel filter is located, can anyone help? Thanks
Tuesday, July 25th, 2017 AT 4:36 PM (Merged)
SERVICE WRITER
  • 9,123 POSTS
Look on the engine compartment rear driver's side along the frame.
DARK_PHOENIX
Thank you for your quick response, is this it?
https://www.2carpros.com/forum/automotive_pictures/200838_IMG_0295_1.jpg
SERVICE WRITER
  • 9,123 POSTS
That's the animal!
DARK_PHOENIX
Thank you so much for your help! Bunch a guys around me and no one mechanically inclined! I have another question listed if you think you can help thanks again!
MJANELIND
Why would I need to raise the vehicle when changing the fuel filter?
DOCFIXIT
  • 18,828 POSTS
Back by tank behind a splash shield
JYTK
  • 1997 MERCURY VILLAGER
1997 Mercury Villager
How to replace the fuel filter?
Sunday, September 1st, 2019 AT 4:47 PM (Merged)
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/forum/automotive_pictures/62217_Fuel_Filter_2.jpg
Locate the filter near right rear tire, there is a plastic clip at each end, spread it with your finger and remove it, if your filter did not come with new ones, try not to break it! Reapeat at other end, unbolt filter and remove! Have a bucket under the work area to catch spilled gas!
JYTK
I did not find the fuel filter in that location. I found one underhood on driverside. I replaced it.
I have a "check engine" light on. I had same problem 18 month ago. I brougt to the deller and a repair was made. Now it back again. A machnic told me that it could be TPS problem which cause by fuel filter. I change the filter, the light still on. Any help will appriciate.
Thanks
