ABS warning light
CROCODILE
  • 2003 MERCURY SABLE
  • 102,000 MILES
The ABS warning light keeps coming on. I usually comes on during the warmer months of the year. During the winter, it usually stays off. It will come on and stay on for a while. Then when I shut the car off and it sits for a while, it will not come on when started. Other times it will stay on for a couple of days. Mostly on when it is warm outside.
Monday, July 15th, 2013 AT 4:30 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,884 POSTS
It sounds like you have a wheel speed sensor (WSS) that is going out. Here is a guide that will help you confirm the problem and get it fixed.
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Once you find the bad sensor replace it, here is a guide that will give you an idea of what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Please let us know what happens so it will help others.
Cheers, Ken
Wednesday, August 23rd, 2017 AT 4:58 PM
FORDEE9R
  • 1999 MERCURY SABLE
  • 6 CYL
  • FWD
  • 84,000 MILES
Brakes problem
1999 Mercury Sable 6 cyl Front Wheel Drive Automatic 84000 miles
The ABS light began intermitantly but is now on constantly. A scan results in not being able to communicate. The best guesses I've received is a loose wire at the ABS computer and/or a bad computer. Any thoughts?
Wednesday, August 23rd, 2017 AT 4:59 PM (Merged)
SOSOMAYBE
I have the same problem, but mine started at about 63K miles. When I had it in for a recall notice, the mechanic at the dealership told me it was a hydraulic problem & that the fix would cost $2500! I had an independent mechanic tell me that if it is the hydraulics, the 2 part numbers I had been given (from the dealership mechanic) are very expensive parts. The downside to all this: I have regular brakes all the time & ABS only part of the time.
If you find out anything more, please let me know!
JRBURT
  • 2004 MERCURY SABLE
  • 6 CYL
  • 75,000 MILES
Brakes problem
2004 Mercury Sable 6 cyl Two Wheel Drive Automatic 75000 miles
why dose the break and anti-lock lights of a 2004 sable come on and the message reads check break system? Pads and shoes were changed
  • 108,179 POSTS
You could have a bad sensor. Have the computer scanned to identify what is causing the light to come on. Most parts stores will do it for free.
Let me know what you find.
