I need to change the PCV valve on my car, unfortunately I'm not able to find it. I am not a pro.
Thursday, March 17th, 2016 AT 12:15 PM
HMAC300
MECHANIC
The PCV valve is located in the valve cover. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Image (Click to make bigger)
SPONSORED LINKS
Thursday, March 17th, 2016 AT 4:26 PM
BIOCHM98
MEMBER
2004 MERCURY SABLE
6 CYL
2WD
AUTOMATIC
69,000 MILES
Where is the PCV valve located on a 3.0L V6?
Tuesday, February 5th, 2019 AT 6:13 PM
(Merged)
BMRFIXIT
MECHANIC
(Merged)
JOYFUL0022
MEMBER
2001 MERCURY SABLE
6 CYL
FWD
AUTOMATIC
52,000 MILES
Where is the PCV Valve located?
(Merged)
MERLIN2021
MECHANIC
Top middle of the engine towards the firewall.
SPONSORED LINKS
(Merged)
APRILMERIWETHER
MEMBER
1 POST
2003 MERCURY SABLE
2,000,000 MILES
The check engine light came on then it started shaking and cutting off at stops. Finaly it would not budge when gas was mashed. It always cranked backup and still does. I notice that the hose was hissinv when I crunk it. The hose is dry rotted and has a hole. Will replacing it correct the problem and get my car moving again?
(Merged)
MECHANIC
I doubt that this will be the sole cause of your problem, but it should be replaced and then further investigations can find the problem, this hose will affect engine performance so replace and get a scan done for any unresolved fault codes, start here.
(Merged)
BRAVESTAR1
MECHANIC
If you still haven't resolved this issue, do replace all six of your spark plug wires. I was having the same issue on a 1998 DOHC Sable, and replacing the wires stopped an issue similar, where stopping at the toll gate caused the car to shut ofrf, then restart pretty easily.
