1998 Mercury Sable Ignition
TURBOHAUL
  • 1998 MERCURY SABLE
  • 6 CYL
  • FWD
  • 12,500 MILES
Vehicle won't start with key inside, ignition lights stays on even when you remove the key, What is could cause this problem?
Do you
have the same problem?
Tuesday, June 8th, 2010 AT 8:18 PM
BMRFIXIT
  • EXPERT
Check and suspect ignition switch actuator
Tuesday, June 8th, 2010 AT 9:37 PM
Recommended Guides
