1993 Mercury Sable EGR Sensor Circuit Code Error
BDG1701
  • 1993 MERCURY SABLE
  • 6 CYL
  • FWD
  • 135,000 MILES
The car has a 3.8L engine and it running rough. I ran a code checker on it and got a message saying the EGR sensor Circuit voltage higher or lower then expected during self test. I was wondering if this means the sensor is bad and needs to be replaced or is it pointing to another issue.
Do you
have the same problem?
Monday, August 18th, 2008 AT 11:01 AM
BMRFIXIT
  • EXPERT
Remove the EGR and check
clean
Tuesday, August 19th, 2008 AT 12:43 PM
Recommended Guides
