1995 Mercury Mystique turn signal heater blower motor
AMPED 88
  • 1995 MERCURY MYSTIQUE
Electrical problem
1995 Mercury Mystique 6 cyl Two Wheel Drive Manual
Hi my turn signals and my heater blower motor quit working together I was told to change the abs fuse that did not work I didnt think it would being abs is for brakes can you please help me with this matter thanks amped
Do you
have the same problem?
Monday, December 29th, 2008 AT 9:12 AM
BLUELIGHTNIN6
  • EXPERT
Hello
Thanks for the donation
First you need to check all fuses. Inside the cab and in the power distribution box underneath hood as well. Sounds like it is a fuse issue, you just have to find out which one. To learn more about testing fuses, click the following link or copy and paste it into a new web browser.
http://www.2carpros.com/how_to/fuse.htm
Hope this helps..
Thanks for using 2carpros.com!
Tuesday, December 30th, 2008 AT 12:08 AM
Recommended Guides
