2002 Mercury Mountaineer power outage
TONY TORO
  • 2002 MERCURY MOUNTAINEER
  • V8
  • AWD
  • 90,000 MILES
My didnt turn on so I gave it a boost like I usually do mind u I need a new battery I was going to wait for this weekend. Anyways so nothing in my car turned on until I was getting a boost all the lights and power was on except my car. There was a clicking sound coming from the power fuse box sdo I removed the fuse thats was clicking is it the fuse or the battery just gave out /
Do you
have the same problem?
Wednesday, July 16th, 2008 AT 5:17 PM
MERLIN2021
  • EXPERT
When you say it has trouble what kind? Clicking? Or nothing at all? If you hear a click, then either the battery is weak, or the starter, possibly bad battery cable connections, check and clean both ends of BOTH cables! Dissconnect negative(-) first, and put it on last! If no click the starter relay is no good! If you already know it needs a battery, replace it before you damage the alternator.
Wednesday, July 16th, 2008 AT 6:15 PM
Recommended Guides
