1999 Mercury Cougar
HEATHER
  • 1999 MERCURY COUGAR
I have a 1999 Mercury cougar with 81000 miles, I recently pulled up three trouble codes on it - P0420 catalyst efficency below threshold (bank 1) P0430 is the second code and it says the same thing but it's for (bank 2) I pulled out both o2 sensors and gave them a good cleaning, i'm still not sure if that was the problem and what it means bank 1 and 2. The last code I pulled up which I think is the main problem is P1519 IMRC (intake manifold runner control) stuck closed. I have a chilton book and I cannot find where the IMRC is located on my 99'. I was wondering if you could help me with this last code and is it the cause of the other two codes? Thanks
Do you
have the same problem?
Sunday, February 19th, 2006 AT 12:08 PM
LOVESCARS
IMRC is the the culprit
Sunday, February 19th, 2006 AT 1:54 PM
Recommended Guides
