1994 Mercury Cougar
JAMES O
  • 1994 MERCURY COUGAR
Engine Cooling problem
1994 Mercury Cougar 6 cyl Two Wheel Drive Automatic 120.00 miles
coolant light won;t go off
Do you
have the same problem?
Sunday, May 31st, 2009 AT 7:21 PM
OBXAUTOMEDIC
  • EXPERT
Hi James,
If you are talking about the Coolant Level Light. It is mounted on the bottom of the coolant recovery tank. If you have fill it to the proper level and it is still on then most likely it is bad.
Sunday, May 31st, 2009 AT 8:14 PM
Recommended Guides
