Alternator belt squeals
GENTRYSM
  • 1999 MAZDA PROTEGE
  • 4 CYL
  • FWD
  • 160,000 MILES
Alternator belt replaced and still squeals when cold. No bearing noise or other indication of binding. Tighten belt and squeal still comes back.
Do you
have the same problem?
Thursday, December 4th, 2008 AT 5:56 PM
This happens when the pulley becomes glazed which happens when you get a small amount of oil or coolant on it. Remove the belt and use 200 grit sand paper and scuff up the pulley.
This guide will show you how to remove all belts so you can do the job.
https://www.2carpros.com/diagrams/mazda/protege/1999
Cheers
Friday, December 5th, 2008 AT 4:51 AM
BRIAN719
MY 1996 Mazda protege does the exact same thing. When it's cold it squeels really loud. It also does it when I turn my stereo and heater are on at the same time.
Monday, February 23rd, 2009 AT 11:09 PM
CEEKAY7
Mine does the same thing when it's cold and damp. Its all fixed once I used the sand paper :) I love this site.
Monday, April 20th, 2009 AT 11:32 AM
Recommended Guides
