Car will not start, I know I know, but
2CARPRO JACK
  • 11,533 POSTS
Thr ground cable doesnmt necessarily need to be fuly insulated, as long as it isnt frayed, causling loss of contact it should be ok, no corrosion either. Id hate to say buy a battery and have it not work, can you swap a known good one in there from another car to test it?
Thursday, December 15th, 2016 AT 6:46 PM (Merged)
LINDATHATSME
  • 1999 MAZDA MILLENIA
Electrical problem
1999 Mazda Millenia 6 cyl Two Wheel Drive Automatic
driving home it died, thought out of gas, put gas in it and it still will not start, i'm not geting fire to the spark plugs, so what can that be?
LINDATHATSME
DOCFIXIT
  • 18,828 POSTS
Is engine turning over faster than usual?
Thursday, December 15th, 2016 AT 6:47 PM (Merged)
WALDEN
  • 7 POSTS
  • 1996 MAZDA MILLENIA
Engine Mechanical problem
1996 Mazda Millenia 6 cyl Front Wheel Drive Automatic
my car gets spark turns over but wont start it has low compression
DOCFIXIT
  • 18,828 POSTS
What are readings?
WALDEN
  • 7 POSTS
It has about 70 compression
DOCFIXIT
  • 18,828 POSTS
Not enough to pop it's rebuild time are all cylinders the same? If yes tear it down
WALDEN
  • 7 POSTS
Well it jumped timing could that be a problem
DOCFIXIT
  • 18,828 POSTS
You mean belt broke?
WALDEN
  • 7 POSTS
No it jumped timing it was my brothers car n he had some 1 put a new belt on it n it aint lined up meaning the arrows
WALDEN
  • 7 POSTS
What will I have to do if I have 2 rebuild it
KIKI88
  • 2001 MAZDA MILLENIA
  • 181,131 MILES
The battery reads 12.8 volts. Has fuel pressure and spark, it tries to crank but nothing happens after that. The guy I bought it from pulled the auto start box(the brain) out and I'm not sure if that will stop if from starting. As to the fuel pressure, the tester reads 38 when starting but not when you turn the key to the on position. The check engine light is not on and there are no codes saved. Any help would be appreciated. Thank you!
DOCFIXIT
  • 18,828 POSTS
Pull front covers off and check
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_106.jpg
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_398.jpg
  • 108,170 POSTS
If you have spark and the proper amount of fuel pressure, it should run unless it is out of time, or there is low compression.
WALDEN
  • 7 POSTS
Im going to donate 20dollars to u guys for yr help but I have 1 more question can that be the problem why my car aint starting and if all the cylinders aint bad do I have to rebuild
KIKI88
Ok thank you. Any ideas as to why there is no fuel pressure when the key is turned to the on/ run Position?
DOCFIXIT
  • 18,828 POSTS
If belt is off couple teeth that would lower compression. One cylinder low would indicate a valve all low and even readings makes me think Timing is issue. All cylinders low usually does not happen sometime if ran really hot rings will go, so if that didn't happen timing good place to start.
  • 108,170 POSTS
Sorry, I thought you said there was pressure. If there isn't, it could be a bad pump, wiring issue, relay. Start by checking to see if there is power in the wiring to the pump. If there is, then the pump is most likely bad. If there isn't, you need to trace the wiring to see where power is lost. I would usually start at the fuel pump relay to see if power is sent at all.
WALDEN
  • 7 POSTS
Does the arrorw have to be lined up the same way
