1999 Mazda B3000 I think this is a computer problem
MARK22
  • 1999 MAZDA B3000
Computer problem
1999 Mazda b3000 6 cyl Automatic 78500 miles
I have checked all sensors, coil, plugs wires, my truck still is running in limp mode. So I bought a new computer from the dealer I thought it would work right out of the box. Does it too have to be flashed. By the why what is a flash for a computer?
Do you
have the same problem?
Friday, February 13th, 2009 AT 7:46 PM
Sorry its long to read but it serves a purpose to fully understand it
Flash reprogramming PCMs is NOT for the feint of heart. It takes a considerable investment in equipment, paying OEM subscription fees to get flash updates on a CD or online, plowing though pages and pages of charts and tables and TSBs to figure out whether or not the calibration software in a vehicle's PCM needs to be updated, and then plunging ahead with the update itself
Yet PCM flash reprogramming is becoming more and more necessary as vehicle modules get smarter and more complex. GeneralMotors estimates that they have released flash updates for as many as 70% of 1995 and newer GM vehicles.
PCM Programming is Nothing New
Would you believe flash reprogrammable PCMs have been in vehicles for more than a decade? The first such application was the 1990 Geo Storm. Why a humdrum car like the Storm would be the first to receive a flash reprogrammable computer system is unknown. You would think GM would have chosen a more high profile vehicle like a Cadillac or Corvette to usher in the new technology. But they didn't. The choice probably had more to do with production scheduling and new model introductions than profile or image. GM knew OBD II was coming and that it would require a new generation of PCMs that were faster, more capable and able to be programmed electronically.
Up to this point, Program Read Only Memory (PROM) chips held all of the PCMs vital calibration information and operating instructions. GM pioneered the replaceable PROM chip as a way of programming a limited number of basic PCMs to fit a wide range of GM makes and models. A replaceable PROM chip also meant the PCM could be "retuned" if necessary to correct certain kinds of emissions or driveability problems. It also meant that if a bug was later discovered in the original factory programming, it could be corrected in the field by simply replacing the original PROM with an updated corrected PROM (a tactic GM has successfully used over the years to fix many factory flaws). Performance enthusiasts also liked replaceable PROMs because the chip could be replaced with one that provided more spark advance, fuel enrichment, a higher rev limit, etc, to squeeze more power out of the engine.
But replaceable PROMS had a serious drawback: there were too many of them! Every model year and every running change meant another PROM had to be created. Every field fix or recall for an emissions or driveability problem created more part numbers to keep track of. We are talking thousands of different PROMS. The General Motors PROM Identification manual that OTC used to provide with their Monitor scan tool and Pathfinder software contained more than 362 pages of GM PROM numbers!
Enter the flash reprogrammable EEPROM (Electronically Erasable Program Read Only Memory) chip. PCMs built with EEPROM chips can be reprogrammed in a matter of minutes without having to remove the PCM or replace a single chip. It is all done digitally with the proper access codes and input data.
Following the Geo Storm, GM began phasing in PCMs with flash reprogrammable chips in a variety of cars and trucks. By 1995, most GM models had the flash reprogrammable PCMs. Ford and Chrysler were also doing the same thing as OBD II arrived on all cars and light trucks in model year 1996. Today, almost all PCMs have reprogramming capabilities as do a growing number of other onboard control modules (ABS, air bags, climate control, body controller, etc.), So changes and upgrades can be made if needed.
Why Reprogram?
As we said earlier, PCMs may need to be reprogrammed for several reasons. One is to fix factory bugs. Every time Bill Gates rushes yet another version of Windows to market to perpetuate the Microsoft revenue stream, it always turns out to have bugs and security holes that were somehow missed but must be fixed by downloading and installing the latest Windows "service pack." It's a never-ending cycle of upgrades and patches. Fortunately, it is not that bad yet with automotive PCMs, but it has become a crutch for automakers who rush products to market that aren't quite ready. This philosophy of "build it now and fix it later" creates a lot of unnecessary recalls, but at least it gives technicians a way to fix factory mistakes without having to replace any parts.
A reflash may also be required if the factory settings for the OBD II self-diagnostics turn out to be overly sensitive - especially after a few years of operation. The same goes for driveability. What works fine in a brand new car many not work so great after 50,000 or 100,000 miles of real-world driving. Changing the fuel enrichment curve, spark timing or some emissions control function slightly may be necessary to eliminate a hesitation, spark knock or other condition that develops over time.
For example, on certain GM vehicles the Check Engine light comes on and sets a code P1406 that indicates a fault in the position of the exhaust gas recirculation (EGR) valve. Cleaning or replacing the EGR valve and clearing the code does not fix the vehicle because the code usually returns. The real problem is the OBD II programming in the PCM. When the PCM commands the EGR valve to open to check its operation, it isn't allowing enough time for the valve to respond. A brand new valve takes only about 50 milliseconds to open but an older valve may take up to 350 milliseconds or longer - which is not long enough to cause a real NOx emissions failure but is long enough to trip a fault code. The fix in this instance is to reflash the PCM with new instructions that allow more time for the EGR valve to respond.
Another example are rich codes that may appear on some late-model GM vehicles. The problem here is that the original OBD II self-diagnostic programming does not allow enough leeway for changes in intake vacuum that occur as the engine ages. After 60,000 miles, intake vacuum isn't as high as in a new engine, which can create a rich fuel condition. The cure is to flash reprogram the PCM to compensate for the drop in vacuum.
When vehicle manufacturers calibrate the onboard diagnostics to meet federal emissions standards, they have to draw the line somewhere as to what operating conditions might cause emissions to exceed federal limits 1.5 times. That is the threshold where a fault code must be set and the Check Engine light must come on. It doesn't mean emissions really are over the limit, but it is possible based on laboratory dyno testing and field experience. Depending on the application, the vehicle manufacturer may even set the limit a little lower just to be safe because the last thing any OEM wants is an expensive emissions recall.
Unfortunately, vehicle manufacturers don't always tell us their diagnostic strategies or even their operating strategies for their computerized engine control systems. Some service manuals include a fair amount of system background information but others provide almost nothing beyond a basic diagnostic flow chart. Maybe the engineers who design this stuff think technicians only need flow charts and assembly instructions to fix vehicles today. But it often takes a much deeper understanding of the system operating logic to figure out what's setting a particular code - especially when the cause isn't obvious.
The best advice when confronted with a troublesome code that keeps coming back or seems to set for no apparent reason is to check for any technical service bulletins that may have been published. Chances are it might be a programming issue that requires a reflash to fix.
Something else to keep in mind with respect to many late-model flash reprogrammable PCMs: if you replace the PCM for any reason, the replacement unit may have to be reflashed before it will start the engine! Some modules are plug-and-play, and are preprogrammed by the dealer so they can be installed ready-to-go. But many need vehicle specific calibration information to run properly. This may require downloading old calibration information from the original PCM (if possible) and reloading it into the replacement PCM, or getting updated calibration information from the vehicle manufacturer to install in the new module.
Some remanufacturers who supply reconditioned PCMs now flash program PCMs for specific vehicle applications. But to do this, they need vehicle information such as the vehicle identification number (VIN), the type of transmission (manual or automatic), the emissions type (federal certification or California), and other options thqat may affect the calibration of the PCM. Your other option is to flash reprogram the PCM yourself.
Friday, February 13th, 2009 AT 8:35 PM
Recommended Guides
