1989 Mazda B2200 engine stalls
RAYMONDVIERA99
  • 1989 MAZDA B2200
  • 4 CYL
  • MANUAL
  • 135,000 MILES
My truck stalls when I am coming to a stop. If I use the E brake or the brake pedal it wants to die, but I can feather the gas a little and it will idle again. Now if I am going in R and brake truck is fine. I thought it was the brake booster or hose so I replaced both. Thought it was the carb replaced with a used one. I have spent my last dime and the problem is still the same. I have even asked a friend who is ase master teck. And he does not know please help I need truck to go to work. Thank you
Do you
have the same problem?
Tuesday, February 17th, 2009 AT 2:24 PM
Check the PCV and EGR valves
Tuesday, February 17th, 2009 AT 2:43 PM
Recommended Guides
