1995 Mazda 626 Won't start
JRYWB329
  • 1995 MAZDA 626
  • 4 CYL
  • FWD
  • MANUAL
  • 17,000 MILES
The car was running, I had a problem with the air bag light coming on. I got under the dash and began unplugging everything. Then plugging back in. During the process the alarm went off, I have an after market alarm system that I have disconnected, now the distributor won't put fire to the plugs. I have tried to replace the wires, distributor cap, rotor, and even the distributor with no fire going to the plugs. What might be causing this? The car was running very well and I would like to get it running again, only I am running out of patience and ideas. I sure hope I can get some help.
Do you
have the same problem?
Tuesday, October 12th, 2010 AT 1:48 PM
Inspect and test the crankshaft position sensor
Friday, October 15th, 2010 AT 5:39 AM
Recommended Guides
