Low beams dont turn on, only when highbeams are set.
ORIAX123
  • 1993 HONDA PRELUDE
Low beams dont turn on, only when highbeams are set. I thought it was the bulbs so I bought some new ones and made no difference. What could be causing this? What diagnostics should I take? Im sure I checked the fuses and were good.
Do you
have the same problem?
Wednesday, July 24th, 2013 AT 8:51 PM
  • EXPERT
Check the headlight switch itself.
Wednesday, July 24th, 2013 AT 9:53 PM
Recommended Guides
