1990 Lincoln Town Car
BIRCHBAYBILL
  • 1990 LINCOLN TOWN CAR
Digital cluster readout too dim in daylight. Do I neeed a cluster or could it be the voltage regulator?
Do you
have the same problem?
Wednesday, June 16th, 2010 AT 9:20 AM
JACK42
Most likely the cluster or the dimmer for the cluster. Remove the dimmer and use a test light to see if the feed wire changes when you dim or brighten it, if nothing the dimmer may be bad, if it works but dash stays dim th ecluster may need to be repaired or replaced
Tuesday, June 22nd, 2010 AT 8:21 AM
