2007 Other Lincoln Models Squeaking
JZIEMIANIN10
  • 2007 LINCOLN
  • 6 CYL
  • FWD
  • 29,000 MILES
2007 Lincoln MKZ with 29000miles makes a squeaking noise from the front driver side tire only when making a left hand turn. It only squeaks if going slow, not when driving fast. What could this be?
Do you
have the same problem?
Wednesday, January 7th, 2009 AT 8:24 AM
RACEFAN966
  • EXPERT
I would check the brakes check the wheel bearings or hub assemblys. If only does it rolling if it does it over bumps only then you need to check the suspension on that side.
Wednesday, January 7th, 2009 AT 10:29 AM
