1998 Lincoln Navigator won't crank
BELINDAANN
  • 1998 LINCOLN NAVIGATOR
  • V8
  • 4WD
  • 11,500 MILES
My Navigator has been slow cranking. The battery posts were corroded really bad so we took off and cleaned. The radio comes on the inside items work but it will not crank. We hot wired the starter and it started. The radio quit and it was a fuse. We put the radio back in and it blowed the fuse again. The radio is now working, but when we went to crank it it would not.
Do you
have the same problem?
Tuesday, July 7th, 2009 AT 7:03 AM
  • EXPERT
Have you checked the starter relay?
Monday, August 17th, 2009 AT 10:41 PM
Recommended Guides
