OVERHEATING
JOLANDA
  • LINCOLN CONTINENTAL
1995 lincoln continental 105,000 miles v8 replaced serpentine belt, radiator, water pump, and gaskets and car is still overheating. It had a leak at first and we plugged the leak now the coolant doesn't leave the reservoir. I was told to check the fans, but before I pay for the seventh time to do another diagnostic, what could be the problem?
Thursday, February 15th, 2007 AT 3:28 PM
SERVICE WRITER
  • 9,123 POSTS
It sounds like you have a blown head gasket which toy can check yourself by following this guide.
this guide can help as well.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Please run down these guides and report back. Cheers,
Thursday, February 15th, 2007 AT 4:43 PM
BHUGG
  • 157 POSTS
I found the head gasket was blown I had to pay $1500.00 to have it fixed. Great site though :)
Tuesday, February 20th, 2007 AT 9:50 AM
RUSMISHANIA
  • 5 POSTS
Hello I have a Lincoln Continental 1998, it has somewhere around 130,000 miles on it and the engine is 8 cylinder 4.6 281c, it started to overheat a little while ago so I changed the temperature sensor and the thermostat and it's still overheating. I thought that it might be a blown gasket but there are no bubbles in the cooling system, so I started looking what else could be the problem. I found out about the Valuable Relay Control Module, the one that is located on the top of the cooling fans. And it also said that this module is responsible for turning the A/C clutch off, and right before the car started overheating, sometimes the air conditioner would just turn off and then come back on. So I focused on this module. Can you please tell me if you think that this is the problem. Maybe you can tell me if there is a way to check this module. I searched everywhere for it but I can't find it. No matter where I look for it, I type VCRM and I they can't find it, even in the FORD website by part number. Maybe you can tell me where I can get one as well. Thank you very much.
Wednesday, October 10th, 2007 AT 2:39 PM
2CARPRO JACK
  • 11,533 POSTS
RusMishania, do you ever hear the cooling fans running? Turn on the a/c and see if the fans come on. If not, my software shows your car doesnt have the Constant Control Relay Module, it has low and hi speed fan relays. If no fan, use a test light and check for power and ground at the fan, get back with results
Wednesday, October 10th, 2007 AT 4:01 PM
RUSMISHANIA
  • 5 POSTS
I just put the Module and the two relays that come with the module on the same plastic bracket back in. I started the car and the fans weren't working. As soon as I turned on the A/C both of the fans came on and I think I heard the compressor come on.
Wednesday, October 10th, 2007 AT 6:27 PM
RUSMISHANIA
  • 5 POSTS
By the way can you tell me for sure if this is the module that we are talking about? In the repair manual they call it VCRM Variable Control Relay Module, you called it Constant Control Relay Module, is it the same thing we are talking about? Here are few pictures of it.
https://www.2carpros.com/forum/automotive_pictures/106456_P1030923_1.jpg
https://www.2carpros.com/forum/automotive_pictures/106456_P1030924_1.jpg
https://www.2carpros.com/forum/automotive_pictures/106456_P1030925_1.jpg
Wednesday, October 10th, 2007 AT 6:41 PM
2CARPRO JACK
  • 11,533 POSTS
What is the exact production date of your car? (Sticker on inner d/s door sill). Does it still overheat? If it does, have it chemical tested for a blown head gasket just to be sure we arent chasing our tails
Thursday, October 11th, 2007 AT 10:24 AM
RUSMISHANIA
  • 5 POSTS
The exact date on the door is 09/97. And to tell you the truth I don't think that there is a need to check for a blown gasket since I started the car yesterday and the fans weren't working but when I turned the A/C on both of the fans came on. Then the car got to normal temperature, stayed there for a little while and started to overheat. I checked the fans and they weren't working with or without the A/C. Somebody told me that it might be a problem with the PCM since the PCM monitors the temperature of the coolant and monitors the air and then sends the signal to the Relay's, one of them is for high speed and the other is for low speed ( the way I understand it), so it has to be something eclectic that commands the fans to come on. And I have no idea how to check the PCM or where to buy a new one. I heard something about reprogramming it, but I have no idea how to do that as well. I wait for your answer, please help.
Michael
Thursday, October 11th, 2007 AT 5:29 PM
2CARPRO JACK
  • 11,533 POSTS
Low speed relay- Check for power at #30 and 86 with car running, 85 should be the ground signal from PCM to turn on fan when it gets hot
High speed-Power at #1 and 3 running, ground at #2 when the PCM wants it to turn on. Check these things, if no signal from PCM when hot, might be time for a new one, or have the it reprogrammed at a shop with the proper equipment or more likely the dealer
Friday, October 12th, 2007 AT 9:19 AM
RUSMISHANIA
  • 5 POSTS
Hello, I wired the fans on the high speed straight to the battery and took a ride. At first the temperature stayed normal, so I gas it up a couple of times pretty good just to check if it's still going to stay normal and then it started to go up again but not as fast as it did before. And the temperature never quite made it to the red but it did go as high on normal as it could. So looks like there is a mechanical problem, do you think it might be a gasket seal? And what else do you think it could be? Thank you for your help, I will wait for your answer.
Mike
Saturday, October 13th, 2007 AT 1:23 PM
2CARPRO JACK
  • 11,533 POSTS
If you have replaced all you say, I would have it chemical tested for head gasket
Monday, October 15th, 2007 AT 8:34 AM
RONNIEKILLOUGH
  • 1994 LINCOLN CONTINENTAL
  • 6 CYL
  • 135,000 MILES
I bought my car and on the way home it got hot I killed it and parked for a few months I thought it blew a hose or head gasket wasnt sure Well I decided toadd water change fuel filter, rotor bug and distributer cap and fire it up after a long try it finallly started and it was missing like crazy but the water was coming out the tail pipes and missing like crazy I could barely keep it ideling enough to move it but I have never seen a car shoot water from radiater to right out tail pipe, What is causing all this.
It is a sweet car and very nice I hope this dont become a expenseive ordeal.
Tuesday, November 20th, 2018 AT 11:23 AM (Merged)
RICK 08
  • 54 POSTS
If the water coming from the tail pipe is from the cooling system, I suspect you may have a blown gasket at best, perhaps a result of the over heating.
This is a costly repair. Unless you can confirm this yourself, taking it in for a estmate is in your future.
BOB MCNABB
  • 1997 LINCOLN CONTINENTAL
  • V8
  • FWD
  • 140,000 MILES
My 97 Lincoln has been serviced by Lincoln for its first 125000 miles I have all the books and records. With that being said. My problem started about a year ago, with it overheating if I drove it more than 50 miles. Now it overheats 6 to 8 miles. Four different shops have tried to fix it. Parts replaced, Water pump, Radiator, Cap, Hoses, Thermostat, both fans, Trans axle flush plus 4 mechanics. Any.I. Suggestions.
BLUELIGHTNIN6
  • 16,542 POSTS
Other than the gauge reading, have there been signs of overheating i.E. Coolant steaming out.
KNDUNCAN
  • 1998 LINCOLN CONTINENTAL
  • V8
  • 163,000 MILES
Keeps overheating. 11/28- replaced upper and lower radiator hoses, water pump, thermostat and thermostat gasket.
12/3 - overheated again. Said thermostat was defective and replaced, again, hoses, and thermostat, thermostat gasket, and radiator reservoir cap. Additionally replaced the serpentine drive belt, drive belt idler pulley and puller tensioneer.
12/7 trip - with similar symptoms (overheating and loosing coolant). Tightened something.
12/15 - similar symptons; said they could not find any problem, although they witnessed the coolant loss. Suggested the fan relay system and suggested we try a dealer mechanic.
12/17 - Ford dealer replaced radiator, hoses, PCV valve assembly
1/27 - Running rough, replaced coil asy, gaskets, spark plugs, degas cap. Picked up the car - went 5 miles and it overheated. Said they are not finding the problem - there is none of the gasses that we would be expected if it was the head gasket.
Thoughts?
2CARPRO JACK
  • 11,533 POSTS
Head gaskets can cause many different symptoms. Dos it still leak externally? If so the cooling system cant work properly, it needs pressure to keep the water from boiling. If no external leaks but it is losing coolant a head gasket may be the problem. You can have a chemical test done on the cooling system to detect the prescence of exhaust gasses. NOTE: sometimes head gasket leaks cannot be detected through chemical testing. Disassembly is the only way to check it.
DAD2ABI
  • 1996 LINCOLN CONTINENTAL
  • V8
  • FWD
  • 154,000 MILES
First the electric cooling fan locked up an started smoking almost catchin fire so I foun them an changed them out the car would run fine for a while till the thermostat will open then straight to overheating I changed the themostat twice an had the water pump changed I cant figure out what is causing it to run hot it wasnt doing none of this before the fan locked up an almost caught fire thanx Please Help an the fans are working like they are supposed to itll run at normal till the thermostat opens then straight to hot sometimes taking up to 30 minutes I dont know please help
SERVICE WRITER
  • 9,123 POSTS
There may be a restriction in the system or damage done when the overheating occured such as a head gasket. Be sure all of the air was bled out of the system.
https://www.2carpros.com/forum/automotive_pictures/30961_cooling_1.jpg
NEGGAONE
  • 1991 LINCOLN CONTINENTAL
Steering problem
1991 Lincoln Continental 6 cyl Front Wheel Drive Automatic
changed the powersteering pump changed the rack and pinon car is still hard to steer and pump is overheating fluid is boiling what could the problem be?
