Engine wiring diagram
J.STIEG
  • 1998 LINCOLN CONTINENTAL
  • 146,000 MILES
I need a wiring diagrams for a 98 lincoln cotinetal. Diagrams of Fuel pump driver module, and wires going to fuel pump, and PCM.
Really appreciate it. Thanks
Do you
have the same problem?
Thursday, April 28th, 2011 AT 6:58 PM
KHLOW2008
  • 41,815 POSTS
Attached are the complete set of schematic diagrams for the engine performance. Hope it is helpful.
Thursday, April 28th, 2011 AT 7:27 PM
WRENCHTECH
  • 20,758 POSTS
The FPDM is behind the back seat, passenger side, accessed from the trunk.
Thursday, April 28th, 2011 AT 8:11 PM
J.STIEG
  • 352 POSTS
Low fuel pressure and code p0190, any Ideas?
Thursday, April 28th, 2011 AT 9:07 PM
WRENCHTECH
  • 20,758 POSTS
You need a scan tool to prompt the FPDM to increase pressure so you can see if the pump FPDM and the pump responds. The code is for the fuel rail pressure sensor so that circuit would have to be troubleshooted. You would need the scan tool for that also.
Thursday, April 28th, 2011 AT 9:27 PM
J.STIEG
  • 352 POSTS
Ok, I can troubleshoot the fuel pressure sensor, Can I get resistance specification. Thanks
Thursday, April 28th, 2011 AT 9:48 PM
WRENCHTECH
  • 20,758 POSTS
No, you can test resistance. It is a 3 wire, 5v reference return sensor. You need to use a scan tool to see what the computer is seeing.
Thursday, April 28th, 2011 AT 9:51 PM
J.STIEG
  • 352 POSTS
What type of scan tool? I have a obd2 reader, bought it a couple of years ago, it cost about 100 bucks. I have software and PC cable. Is a scanner and reader the same thing?
Friday, April 29th, 2011 AT 9:07 PM
WRENCHTECH
  • 20,758 POSTS
No, not at all. What you need costs more in the $8,000 range.
Friday, April 29th, 2011 AT 9:48 PM
J.STIEG
  • 352 POSTS
Ok, I tested resistance on FRP sensor. On sensor FRP to VRFE: 44.2k ohms, FRP to Sig Rtn: 44.2k ohms, and VREF to Sig Rtn: 1.4k ohms.
Also tested all 3 wires for opens between sensor and PCM and there was none.
Code p0190 is the only code that comes on, and wires going to FPRS are shared by lots of other sensors.
Saturday, April 30th, 2011 AT 3:59 AM
WRENCHTECH
  • 20,758 POSTS
This could be bad PCM. I would find a used one and plug it in.
Saturday, April 30th, 2011 AT 11:06 AM
GARYCOX100
  • 1997 LINCOLN CONTINENTAL
  • V8
  • FWD
  • 214,359 MILES
I want to know if the wiring harness for a 1996 continetal is the same as the 1997
Sunday, December 8th, 2019 AT 7:10 PM (Merged)
BLUECOLLAR
  • 86 POSTS
Being an old Ford guy, I'm sure theres a difference somewhere between the two. For the heck of it, I called a buddy of mine I used to work with at a dealership years ago and according to him, unless you had the tag off of the wiring harness, they wouldn't even order one. In other words, with all the different options and all available for these cars, even if it was the exact same year. The harness maybe different.
BTW, why are you wanting to replace the harness anyway?
REDLINE13K
  • 1996 LINCOLN CONTINENTAL
  • 180,000 MILES
Vechicle is a 4.6. Im looking for a wiring diagram for the fuel pump system. A test light on the pink/black wire to the pump flashes bright very quickly then gives a couple of dim flashes, not the on for 1.5 seconds like it should. It also does the same thing on the pink/black wire coming out of the FP driver module in the trunk. Thank you for any information
HMAC300
  • 48,606 POSTS
Hereis a diagram but check the fp module as i've seen some tipson capacitors going bad inside them and check to make sure inertia switch isnt' engaged.
REDLINE13K
Inertia switch is good. Is there a fuel pump relay in the sealed relay pack on top of the radiator? Or does the Module in the trunk run it all? Just wondered where the other 2 wires go. Im thinkink its the FP module. Thank you so much!
