Cooling fans are running all the time
MUDRULZ
  • 2000 LEXUS ES 300
  • 148,000 MILES
Have a 2000 es300 and replaced the battery and now the cooling fans start and run all the time. What could be happening at this point?
Monday, January 9th, 2012 AT 5:53 AM
CJ MEDEVAC
  • 11,004 POSTS
It sounds like one of the cooling fan relays is stuck on here is the relay location with a guide to test them and the fan wiring diagrams so you can see how the system works.
Monday, January 9th, 2012 AT 7:05 AM
OXAMANDUHX
  • 11 POSTS
Try the cooling fan sensor.
Wednesday, February 8th, 2012 AT 9:20 PM
MUDRULZ
Tried the cooling fan relays and the cooling fan sensor and the fans still run all the time even after engine is fully warmed up. Will the next step be to go to the dealership and have them put it on a computer? Thanks David
Tuesday, April 24th, 2012 AT 4:09 AM
CJ MEDEVAC
  • 11,004 POSTS
It sounds like the ECM go hurt from a possible backward jump when the battery was low.
Tuesday, April 24th, 2012 AT 4:32 AM
STAN 1
  • 0 POST
I had this same problem, it was the ECM shorted out, got sued one for $80.00 all fixed.
Wednesday, February 6th, 2019 AT 3:02 PM
NB2B
  • 1999 LEXUS ES 300
Electrical problem
1999 Lexus ES 300 6 cyl 100, 00 miles
I parked up my car after returning from lunch and returned to a dead battery. Further investigation revealed that the engine cooling fans were not shutting off and continued to run.
Wednesday, February 6th, 2019 AT 3:02 PM (Merged)
Check the engine temperature gauge switch and also the fan relay
ATKAPARKING
  • 64 POSTS
The fan is designed to run until the engine is cool. How long did the fan run? I'd also check battery condition as well.
