P1155 Air Fuel Metering or oxygen sensor?
LXSES300
  • 1999 LEXUS ES 300
Engine Performance problem
1999 Lexus ES 300 6 cyl Automatic 140, 00 miles
A friend hooked up my '99 ES 300 to diagnose (check engine light is on), the following came up:
Code # P1155 Air Fuel Metering
02 Bank 2 sensor 1
Where exactly is this sensor?
Thank you so much for any help.
Kirsten
Tuesday, October 21st, 2008 AT 9:54 AM
Hi LxsES300 and welcome to 2carpros
The B2S1 is located on the left exhaust manifold see item location no.13 below and this guide will walk you through the steps with instructions in the diagrams below for your car. Here are all of the oxygen sensor locations. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Thursday, October 23rd, 2008 AT 1:16 PM
98LEXUS
  • 1998 LEXUS ES 300
  • 6 CYL
  • FWD
  • 91,000 MILES
I was told after a recent diagnostic of a check engine light that the B1S1 O2 sensor (before catalytic converter) and MAF sensor had failed. I asked the service man if a failure of the O2 could make it appear that the MAF had failed which would make sense to me if that particular O2 sensor were a feedback to the system containing the MAF. He said no. What is your opinion?
I have seen Chilton's and Mitchell's repair manuals referenced in responses. Are either of these a good manual for a "beginner" like myself?
Monday, June 1st, 2020 AT 1:37 PM (Merged)
RACEFAN966
  • 5,029 POSTS
Ok first I would replace the O2 sensor and then get some mass air flow cleaner and clean the mass air flow and then go to a parts store that offers a free scann and have them clear the codes if it comes back then go from there.
