Where is the knock sensor located? I need to replace it.
Wednesday, February 27th, 2013 AT 2:00 AM
SATURNTECH9
MECHANIC
There are two knock sensor one on each side of the block here are diagrams and instructions so you can replace the sensor. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to make bigger)
SPONSORED LINKS
Wednesday, February 27th, 2013 AT 3:16 AM
NICKTHEBEST
MEMBER
2006 SATURN VUE
3.5L
6 CYL
FWD
AUTOMATIC
75 MILES
Hi! I have an 06 Saturn Vue with the Honda 3.5 engine in it, does anyone know where the knock detonation sensor is located on this engine? I am not sure if I am saying it correctly. It might just be called the knock sensor I am having a hard time finding this, so any help would be appreciated. Thank you!
Wednesday, February 20th, 2019 AT 1:43 PM
(Merged)
SATURNTECH9
MECHANIC
It should be under the intake manifold, do you have a code for the knock sensor? I have seen rodents chew the wires to them. They nest under the manifold and chew the wires to the knock sensor. I have seen the wire to it chewed far more often then the sensor itself going bad.
(Merged)
SATURNTECH9
MECHANIC
Also I have replaced the knock sensor and the harness without removing the I take manifold before. Your engine is a interference fit engine. But if the timing belt is off by one tooth you could have a rough idle and run fine down the road.
(Merged)
RENEE L
ADMIN
Thank you for visiting 2CarPros. Please let us know if the suggestion given here were helpful so that we can help others with the same issue.
SPONSORED LINKS
(Merged)
JRBOWEN03
MEMBER
2004 SATURN VUE
Computer problem
2004 Saturn Vue 6 cyl Front Wheel Drive Automatic
Where is the knock sensor at and how do I replace it?
(Merged)
MECHANIC
What's the engine liter?
(Merged)
JRBOWEN03
MEMBER
3.5
(Merged)
MECHANIC
The KS is at no. 9 see below
(Merged)
JRBOWEN03
MEMBER
What parts am I going to need to remove to get to the KS?
(Merged)
76SRAGON
MEMBER
1 POST
Hi, am I new to this? Do you have images or videos of the location of the Knock sensor in a 2004 Saturn Vue? Thanks
Wednesday, November 4th, 2020 AT 6:46 PM
DANNY L
MECHANIC
Hi i'm Danny.
I have attached pictures below of the 4 cylinder and 6 cylinder engine knock sensor location as it did not specify. I am attaching a tutorial showing what the replacement entails, but it is in English. The 4-cylinder image is # 3 and the 6-cylinder image is location # 9.
