The vehicle has No reversing lights, I have checked all relevant fuses. Help!
Friday, August 16th, 2013 AT 8:50 AM
WRENCHTECH
MECHANIC
It sounds like the switch is bad which is common (gear range sensor). Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to make bigger)
SPONSORED LINKS
Friday, August 16th, 2013 AT 9:16 AM
JNDUNNIVAN
MEMBER
1 POST
2006 KIA SPORTAGE
We need to find the back-up light switch. To replace it can you tell us where it is?
Tuesday, March 30th, 2021 AT 2:13 PM
(Merged)
BLUELIGHTNIN6
MECHANIC
Back up lamp switch is on the top of the transaxle. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
(Merged)
BOBGILES4819
MEMBER
2000 KIA SPORTAGE
0.5L
4 CYL
4WD
AUTOMATIC
123,000 MILES
I keep blowing the meter fuse. I replaced the speed sensor but but still the problem.
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
The reverse switch is down on the transmission. Here is a guide to show you what you will be in for when doing the job:
