Transfer case stuck
STEVECARPIO
  • 2003 KIA SORENTO
  • 6 CYL
  • 4WD
  • MANUAL
  • 150 MILES
My 4X4 is stuck on four low turned switch to 2HI and nothing. Is there a way to do it manually
Monday, May 30th, 2011 AT 12:36 AM
KHLOW2008
  • 41,815 POSTS
Is the 4WD light staying on or blinking?
Disabling 4WD manually would have to depend on what is wrong.
Heres a guide on using a test light
Test all of the fuses first, if good then check for power at the transfer case motor
See diagram below
Monday, May 30th, 2011 AT 3:25 PM
FIVEOO
  • 2003 KIA SORENTO
  • 6 CYL
  • 4WD
  • 95,000 MILES
My 4 wheel drive tries to engage and makes a loud noise like its engaging and then disengaging. The light comes on to show that its in 4 wheel but doesn't engage
Thursday, March 14th, 2019 AT 6:32 PM (Merged)
  • 108,133 POSTS
Check the actuator at the transfer case to see if it gets continuous power. If it does, have the actuator checked and replaced if needed. IF the power is broken, have the switch and wiring checked.
KIADUDE62
  • 2003 KIA SORENTO
  • 6 CYL
  • 73,258 MILES
My 2003 Kia Sorento is stuck in 4 wheel low. I have the knob which you turn inside the car. Car however does not want to go out of 4 wheel low. How do I get it out of that?
  • 108,133 POSTS
I need you to check the 4wd actuator is getting power when you turn the knob. If you are getting power, chances are the actuator is bad. If there is no power, work backwards to the switch. Check for damaged or broken wires. Check the switch itself.
TADA
  • 2005 KIA SORENTO
  • 110,000 MILES
Its not changing gears
RIVERMIKERAT
  • 6,110 POSTS
Have it scanned for both hard and soft codes. We need codes that begin with either a U, B, or C.
ZAIDEMAJEED
  • 2007 KIA SORENTO
  • 100,000 MILES
Good day my 4x4 low light remain on the dash I got the car scan it came up with P1729 what should I do
  • 52,797 POSTS
Component Location
General Description
TCCU control EMC (Electric Magnet Clutch) by current and EMC distribute torque properly by using slip amount of multi-clutch.
DTC Description
As related to EMC, this trouble code is set if EMC output harness is shorted to ground.
DTC Detecting Condition
this has nothing to do with your issue. You need the 4 wheel system scanned for the issue, not the engine
GREASESPOT
  • 2006 KIA SORENTO
  • 120,000 MILES
Sometimes the 4WD high comes on when I start it (switch is still on 2WD), then turns off 10 seconds later (I hear it disengaging). Or sometimes it stays on so I turn the switch to 4WD, wait, then turn it off and it goes off.
It also engages while I'm driving, then turns off.5 to 10 seconds later.
Dealer says it's the 4WD control module, which is $1200. What POs me is I told another dealer about it repeatedly when it was still on warranty and they didn't find or do anything about it.
Suggestions? Comments?
  • 108,133 POSTS
You should get in touch with the dealer you told about the problem while it was under warranty. They should be able to get it under warranty.
GREASESPOT
Even if they didn't write it up?
  • 108,133 POSTS
If you can speak with the person that talked to you about it, I would think so if they are honest and want to be helpful. It's worth a try.
RICKSCHUMAKER
  • 2004 KIA SORENTO
  • 6 CYL
  • 4WD
  • 151,068 MILES
When turning at slow speeds (parking lot maneuvers), the rear wheels were binding up really badly. At times would bring the vehicle to a complete stop. I had the transfer case disconnected by cutting a wire to the transfer case. Vehicle runs fine, and I don't care about having 4wd at this point. Question is, will this have an effect on my transmission? I'm just trying to make this thing last as long as possible.
GREASESPOT
It sure is worth a try, at $1200 for the part.
I'll give it ta try.
But what else could be causing it? I get lots of other possibilities when I do a Google search, including the transmission control module, which I believe is also reprogrammable. Could programming be it? Also, would this fault show up in their computerized troubleshooting/error codes?
HMAC300
  • 48,601 POSTS
It won't hurt the 4wd but you may have a wheel bearings bad in car causing the binding or something in tcase doing it. It will set a code with the wire cut however.
RICKSCHUMAKER
Yes, I now have a flashing light indicating the transfer case is inop. Its not a bearing, as everything is fine now and the vehicle drives fine. I just want to make sure that I'm not doing additional damage to the transmission itself.
HMAC300
  • 48,601 POSTS
Nope
BBQ MAN
  • 2006 KIA SORENTO
Drive Train Axles Bearings problem
2006 Kia Sorento Four Wheel Drive Automatic
I had to put her in 4-low to get out of a "spot" now I switch the dash control to 2- wheel or 4-high. Won't come out. Do I need to back up for X amount of feet? Car can't go much more than 20 mph without the engingine screaming.
  • 108,133 POSTS
That is all the faster it should go in 4lo. Don't push it. As far as the 4wd, check to see if you are getting power to the 4wds actuator at the transfer case. Let me know what you find.
