Timing mark diagram
ANGELIQUE
  • 1997 KIA SEPHIA
I need a diagram of the timing marks on a 1997 Kia Sephia 1.8L. CCould you help me find one?
Thursday, April 14th, 2011 AT 12:18 AM
Here is a guide and the diagrams below so you can see how the job is done:
https://www.2carpros.com/diagrams/kia/sephia/1997
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed. Cheers
Thursday, April 14th, 2011 AT 3:51 AM
GEORGE988
  • 1998 KIA SEPHIA
  • 4 CYL
  • FWD
  • 130,000 MILES
How do I reset the in belt to the right timing position?
Thursday, September 27th, 2018 AT 3:17 PM (Merged)
DAVE H
  • 13,383 POSTS
Timing belt
Removal
Disconnect negative battery cable. Remove all accessory drive belts. Remove generator bolts. Remove water pump pulley. Remove crankshaft pulley bolt, and remove pulley and timing belt guide plate.
Remove upper and lower timing belt covers. Rotate crankshaft clockwise until No. 1 piston is at TDC of compression stroke. Ensure camshaft sprockets and crankshaft sprocket timing marks align. See Fig. 2 and Fig. 3 . Camshaft sprocket "I" and "E" marks must face up and align with marks on rear timing belt cover.
If reusing old timing belt, mark belt with arrow to indicate original direction of rotation. Remove timing belt tensioner pulley. See Fig. 4 . Remove timing belt.
Fig. 2: Aligning Camshaft Timing Marks
Courtesy of KIA MOTORS OF AMERICA, INC.
https://www.2carpros.com/forum/automotive_pictures/266999_2_10.jpg
Fig. 3: Aligning Crankshaft Timing Marks
https://www.2carpros.com/forum/automotive_pictures/266999_3_15.jpg
Fig. 4: Timing Belt Tensioner & Idler Pulley
https://www.2carpros.com/forum/automotive_pictures/266999_4_9.jpg
Inspection
Check timing belt for cracks, peeling, abrasion or other damage. Check tensioner and idler pulley bearings for looseness or roughness of rotation. Inspect tensioner spring for stretching. Replace parts as necessary.
NOTE:Manufacturer recommends replacing timing belt tensioner spring whenever timing belt is replaced.
Install tensioner pulley with NEW spring. Move tensioner away from timing belt, and tighten center bolt. Ensure camshaft and crankshaft timing marks are still aligned. See Fig. 2 and Fig. 3 .
Install timing belt around crankshaft sprocket. If reusing old belt, ensure belt is installed in original direction of rotation. Keeping belt pulled tight on right side (facing engine), route belt around idler pulley, camshaft sprockets, and tensioner pulley.
Loosen timing belt tensioner center bolt, and allow spring to apply tension on belt. Tighten tensioner center bolt. Rotate crankshaft clockwise 2 complete revolutions. Ensure timing marks align. If timing marks are not aligned, remove belt, realign all timing marks, and repeat installation procedure.
Check timing belt deflection with 22 lbs. (10 kg) of downward pressure applied to belt, midway between camshaft sprockets. Timing belt deflection should be .36-.45" (9.0-11 mm).
If timing belt deflection is not within specification, repeat timing belt tensioning procedure. If timing belt deflection is within specification, install timing belt covers. Install crankshaft and water pump pulleys. To complete installation, reverse removal procedure. Adjust drive belts to proper tension.
KASONDRA21
  • 1995 KIA SEPHIA
  • 4 CYL
  • MANUAL
  • 110,000 MILES
I need to know what the timing marks are for this car. Maybe a diagram as well.
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_sephiatime_1.gif
https://www.2carpros.com/forum/automotive_pictures/55316_sephia2_1.gif
https://www.2carpros.com/forum/automotive_pictures/55316_sephia3_1.gif
https://www.2carpros.com/forum/automotive_pictures/55316_sephia4_1.gif
https://www.2carpros.com/forum/automotive_pictures/55316_sephia5_1.gif
https://www.2carpros.com/forum/automotive_pictures/55316_sephia6_1.jpg
MANDE CASSELL
  • 1998 KIA SEPHIA
  • 4 CYL
  • FWD
  • MANUAL
  • 176,000 MILES
What would cause the timing belt to break after four months of just replacing it.
DAVE H
  • 13,383 POSTS
Could be a bad belt or bad tension-er or even a bad repair.
