Drive belts
LAMM90
  • 2005 KIA AMANTI
How do I release the tension to change the belts?
Thursday, July 2nd, 2009 AT 1:10 PM
DAVE H
  • 13,383 POSTS
BELT ADJUSTMENT
Power Steering
Loosen hinge bolt "A" and flange nut "B". See Fig. 4 .
Turn adjusting bolt "C" to set belt tension . See Fig. 4 and Fig. 5 .
Tighten hinge bolt "A" and flange nut "B" to specification.
Alternator & Air Conditioning Compressor
Loosen pulley lock nut "A". See Fig. 6 .
Turn adjustment bolt "B" to set belt tension . See Fig. 6 and Fig. 7 . See BELT ADJUSTMENT table.
Tighten pulley lock nut "A" to specification.
Start engine and turn A/C on.
Allow vehicle to run until normal operating temperature is reached.
Turn engine off, recheck belt deflection after operation and readjust belt tension as necessary.
https://www.2carpros.com/forum/automotive_pictures/266999_kia_38.jpg
https://www.2carpros.com/forum/automotive_pictures/266999_kia2_1.jpg
Sunday, November 8th, 2009 AT 6:34 PM
2CP-ARCHIVES
  • 4,542 POSTS
  • 2005 KIA AMANTI
  • 10,000 MILES
How to replace power steering belt
Friday, May 10th, 2019 AT 6:34 PM (Merged)
KHLOW2008
  • 41,815 POSTS
P
ower Steering
1. Loosen hinge bolt "A" and flange nut "B". See Fig. 4.
2. Loosen adjusting bolt "C" until you are able to get belt off.
3. Install new belt. After belt is seated, pull it to slide around pullies to ensure it is seated correctly.
4. Turn adjusting bolt "C" to set belt tension to specified deflection.
5. Tighten hinge bolt "A" and flange nut "B" to specification.
CH311
  • 2005 KIA AMANTI
  • 6 CYL
  • FWD
  • 78,000 MILES
Need a serpentine belt diagram for a 2005 kia amanti
DAVE H
  • 13,383 POSTS
https://www.2carpros.com/forum/automotive_pictures/266999_am_2.jpg
RICK MAHAN
  • 2008 KIA AMANTI
  • 3.8L
  • 6 CYL
  • 103,320 MILES
Serpentine broke, need to replace but it seems too long following diagram.
WRENCHTECH
  • 20,757 POSTS
Here is the diagram.
RICK MAHAN
Thank you so very much. It worked. Your help is very much appreciated.
WRENCHTECH
  • 20,757 POSTS
You are welcome.
