Key will turn over motor will fire but ignition will not spark
ITSMEDEANAD
  • 1992 BUICK SKYLARK
  • 3.3L
  • 6 CYL
  • FWD
  • 50,000 MILES
Key in the ignition will turn over but does not mean there is a spark to start the vehicle. Sometimes it will start right up the key turns it over but does not mean the ignition is firing to start the vehicle. What is wrong with the damn thing? I have replaced the ignition modules three times I have had it hooked up to a computer and the module is fine they said it was something after the ignition switch actuator rod or something I just do not know what that part is after that. Can you help me?
Do you
have the same problem?
Tuesday, October 27th, 2015 AT 9:27 AM
CAR-MAN145
  • EXPERT
You may have a bad crank sensor
Wednesday, October 28th, 2015 AT 1:16 AM
Recommended Guides
