Location of neutral safety switch
MARK1712
  • 2002 JEEP WRANGLER
  • 6 CYL
  • 4WD
  • MANUAL
  • 80,000 MILES
Inst pan will light up but starter is not geting any power. Engine will start up when starter system is bypassed and started will turn when removed and tested. Think it is the neutral safety switch but dont know where to find it.
Monday, January 5th, 2009 AT 10:35 AM
RACEFAN966
  • 5,029 POSTS
The neutral safety switch is located on the transmission here is a diagrams to show you what it looks like. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Monday, January 5th, 2009 AT 11:41 AM
RI6044
Electrical problem
2002 Jeep Wrangler 6 cyl Four Wheel Drive Automatic
How do I get to the neutral switch to replace it and if it is bad would it keep the back up lights from working?
Friday, July 5th, 2019 AT 7:17 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Since its equipped with an automatic transmission, yes a faulty Park / Neutral Position Switch will also cause the back-up lights to fail. Your vehicle's PNP switch is located on the left side of the transmission.
RI6044
I looked on the left side & didn't see it. Where on the transmission do I need to look?
BLUELIGHTNIN6
  • 16,542 POSTS
Look just behind where the linkage is fastened
