1997 Jeep Wrangler NOT ALWAYS STARTING
JEEP1979
  • 1997 JEEP WRANGLER
  • 4 CYL
  • 4WD
  • 132,000 MILES
FUEL FILTER, FUEL PUMP, PLUGS, DIST CAP, CRANK SHAFT POSITION SENSOR, FUEL PUMP RELAY HAVE ALL BEEN REPLACED- WILL START MOST OF THE TIME BUT OUT OF THE BLUE (MIGHT BE SITTING FOR 2 DAYS OR EVEN 30 MINUTES) IT WILL CRANK BUT NOT START UNLESS YOU PUT GAS IN THE AIR INTAKE. THEN IT STARTS AND RUN DOESNT MISS OR SMOKE AND KEEPS RUNNING. CAN YOU PLEASE HELP!
Do you
have the same problem?
Tuesday, June 29th, 2010 AT 1:20 PM
Check the fuel pressure if it's within specs.
Tuesday, June 29th, 2010 AT 6:27 PM
Recommended Guides
