Engine will not start and run?
SDEYE
  • 1995 JEEP WRANGLER
  • 13,800 MILES
Replaced coil, fuel pump fuel filter crank sensor also put diff computer from running jeep same as mine still no start
Do you
have the same problem?
Monday, December 5th, 2011 AT 10:46 PM
  • 108,005 POSTS
Are you getting spark and fuel to the engine? Will it start with starting fluid? When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Monday, December 5th, 2011 AT 10:50 PM
MULDOON
  • 79 POSTS
Had same problem with my JGC laredo eventually had to replace computer with new one, each computer is set for that car that is what I believe, good luck Dec
Friday, December 16th, 2011 AT 2:01 PM
LELAND7197
  • 7 POSTS
  • 2.5L
  • 4 CYL
  • 4WD
  • MANUAL
  • 190,000 MILES
Jeep was running then went to start but want checked fuses and relays. Is not firing. Need some help!
Thursday, September 24th, 2020 AT 6:23 PM (Merged)
HMAC300
  • 48,606 POSTS
Scan for codes and check crank sensor. Do wiggle test on crank sensor connector if it starts you'll need another connector. Check fuses underhood.
LELAND7197
  • 7 POSTS
Where would you find it? I looked for it yesterday and then call a auto parts and they said there is not a listing of one on that model. I was getting power to my coil but fire out of the spark plug. So have replaced the rotary button, distributor cap, and coil Checked rotary button to see if if was spinning it was. I am getting fuel to the fuel injectors.
HMAC300
  • 48,606 POSTS
If you are getting a nice spark to the dist cap then sand down the contacts inside the cap and make sure the cap isn't cracked and wire from coil is good. Ya know I love autoparts guys they will tell you anything you want to hear. See pic for sensor location.
LELAND7197
  • 7 POSTS
Going to find it now. Let you know what I find out. Thanks
LELAND7197
  • 7 POSTS
I found it took it out clean it up with some light grad sandpaper still Wil no crank can you tell me what I senses. It it some type of magnetic if it was it was not that strong.
HMAC300
  • 48,606 POSTS
Ya know when you guys say it won't start say it won't turn over that is a whole different ballgame. The crank sensor is magnetic. First you check your battery for condition including load test autoparts can do it. Does it not turn over or not run what is your fuel pressure like asked in very first reply? I really think this is to much for you. Ittells the module when to fire. Have you check ed fuses underhood or only in dash. Check the coil with an ohm meter shold be 9.5-1.20 between small terminals an d11,000-14,000 between negative terminal and large output where the plug wire goes. If out of range then the coil is shot. I have no further comments or suggestions.
HONSELLD
  • 4 CYL
  • 4WD
  • MANUAL
  • 119,891 MILES
The colder the mornings have gotten, the harder it is to start. I've noticed that when I turn the key to the 'on' position, if I wait in silence - not turning the starter over - I wait until I hear a rapid clicking sound, then when I engage the starter the motor starts every time. If I turn the starter over before I hear the clicking sound it will not start- it just turns over. I've had a friend turn the key to 'on' while I'm beneath the hood before, and I found the clicking is coming from the power distribution box- specifically the relays are clicking- I can feel it with my fingers. I have replaced both the starter and fuel pump relay switches, but problem still exists. I have replaced the fuel pump also. It seems the problem is electrical, I'm wondering is it the computer? I should note that the battery has plenty of juice, and the starter acts as it should every time I turn it over.
Check the fuel pressure and if okay-inspect and test the engine coolant temperature sensor-comeback with results-
ROBMM76
I'm having the same problem. 1995 2.5 L. Replaced plugs, wires, cap, rotor. ECT tests in range. Seems to hold fuel pressure overnight. I've noticed that often the check engine light does not come on and codes will not display. I turn the ign off for several seconds and try again, often many times, the engine will not start. Eventually the light comes on and the engine will start and it runs just fine. Sometimes it takes several hours. Once I opened the hood and let the sun heat the engine for a couple of hours and it started right up; may be a coincidence. Getting only the meaningless codes 12 and 33 for the past several weeks, including before it got cooler overnight and started having this trouble.
MASTERWRENCH
  • 258 POSTS
Good morning.
I would start by verifying power at the fuel injectors and ignition coil. You should see power for about 2-3 seconds when the key is first turned on. After that, power should be continuous while the engine is cranking or running. See the attached diagrams of the injector and ignition coil wiring. The dark green w/orange tracer are the 12v power supply circuits(which are highlighted). If you do have power, we'll then have to determine if the injectors/coil are getting a signal from the PCM to fire. If there isn't power, we'll have to trace down that side of the system.
Let me know what you find!
SHERRYBLISS
  • 4 CYL
  • 4WD
  • 116,000 MILES
Turn jeep on will not fire for 10min or so than after it clicksthe check engine light comes on and it will start
KHLOW2008
  • 41,815 POSTS
Seems an error has been detected in the engine management system and when the CEL turns on, the component concerned has been disable whereby the engine computer would revert to back-up mode for the sensor. You would need to retrieve the trouble code to understand what is wrong and continue from there.
SINFULRIDES32
  • 6 CYL
  • 4WD
  • 75,000 MILES
My jeep wont start. It ran and then it backfired and stalled. It started after that. Then it shut off. It sat a couple of days and then it started again and did not run after that it seems like some type of a fuell problem
Thursday, September 24th, 2020 AT 6:24 PM (Merged)
MECHCURT
  • 184 POSTS
Lets start with the basics. Test the fuel pressure and compare it to a manual and see if its in specs. Next test for fire at the plugs. Let us know from here what you have. Curt
SUSANNAJEEP
  • 6 POSTS
  • 4 CYL
  • 4WD
  • MANUAL
  • 139,000 MILES
I bought this jeep this summer. Worked fine. Then when it started to get cold, it started to get hard to start. I took it to my mechanic and they started to replace stuff on it, first the starter, then the fuel pump. I can't even think of everything that we have replaced! It is now 20 degrees and it has been towed twice and they can't get it started! They have had it for a week. Can't figure out what the problem is. It was none of the things we have fixed! I have read on the internet that this is a problem with wranglers and no one seems to know what causes this. Can you help me please! I have spent over $4000. They are now working on it for free.
DOCFIXIT
  • 18,828 POSTS
Hi Have them check ECT and IAT see diagram the colder the higher the resistence. Tells computer to inerease injector pulse and timing.
Hope this helps Thanks for donate
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_232.jpg
SUSANNAJEEP
  • 6 POSTS
They have checked this. They even rebuilt the relay system. He said that it's getting fuel but not spark. Sorry, I am trying to communicate to you what he is telling me!
