1998 Jeep Laredo dies and sputters when driving and at idle
SHELLC70
  • 1998 JEEP LAREDO
1998 Jeep Laredo 6 cyl Automatic 137000 miles
1998 Jeep Grand Cherokee Laredo - Been having trouble shifting gears for a while especially between 2nd & 3rd. About 2 months ago began dying at idle or at redlights. After lots of repairs seems to be shifting worse and now dies at idle or at lights, sputters & dies while driving, sometimes hard to crank, then doesn't won't stay cranked. Doesn't happen all of the time, but now more frequent. Replaced computer, crank sensor, upstream & downstream O2 sensors, spark plugs & wires, ignition coil, ignition cap & rotor, cleaned throttle body & injectors. No codes. Also checked transmission and vacuum hoses - says ok. No one can seem to figure this out. Non-related work done: oil leaks in rear & gasket, catalytic converter, AC switch.
Do you
have the same problem?
Saturday, October 24th, 2009 AT 6:25 PM
  • EXPERT
Has anyone checked the fuel pump pressure?
Monday, November 9th, 2009 AT 9:58 AM
Recommended Guides
