1984 Jeep CJ7 Won't Fire the engine
MIKEMAGS
  • 1984 JEEP CJ7
Engine Mechanical problem
1984 Jeep CJ7 6 cyl Four Wheel Drive Manual na miles
My jeep was running fine but the fuel gauge did not work. So, I replaced the Gauge, Sending unit in the tank and fuel filter. The jeep fan for about 2 minutes after doing all of this and then stopped like it was out of gas. Now it will not fire. I used starter luid and it fires for 2 seconds when the fluid burns off. What could it be. Do I need to prime the fuel lines? How? Thanks
Do you
have the same problem?
Thursday, April 24th, 2008 AT 8:34 AM
Check the fuel static and hold pressure
Sunday, April 27th, 2008 AT 4:35 AM
Recommended Guides
