1983 Jeep CJ7 Ignition Coil Failure
MIKEYG
  • 1983 JEEP CJ7
Electrical problem
1983 Jeep CJ7 6 cyl Four Wheel Drive Manual 120K miles
Recently after driving my 1983 Jeep CJ7 for a while the Ignition Coil gets very hot and will quit working. The motor will run rough and bog down then die. It will not start again until the coil has cooled down. If I put a cold replacement coil in it will fire right up. What could be causing the coil to overheat? The engine temp gauge reads normal temp when this happens.
I have checked the + and - wires to the coil and they are hooked up correctly.
Thank You in advance for your help,
Mike Glidden
Littleton, CO
Monday, January 19th, 2009 AT 6:52 PM
What is the battery voltage on the positive side of the coil also does it have a condenser/capacitor on it.
Monday, January 19th, 2009 AT 7:06 PM
DMCAGLE
  • 6 POSTS
My cj7 was running fine but when I turned ignition off it kept running so I pulled coil wire now it wont start back up.
Wednesday, September 26th, 2012 AT 7:50 PM
CJ MEDEVAC
  • 11,004 POSTS
OK BUDDY
I'M HERE FOR THE LONG HAUL.....SEE OTHER CJ ANSWERS IN THE "5" AND "7" FORUMS...YOU'LL UNDERSTAND
DO YOU KNOW YOUR STUFF? OR ARE YOU A BEGINNER?
DO YOU HAVE A REPAIR MANUAL?
https://www.2carpros.com/questions/2007-ford-taurus-tune-up
A VOLTMETER?
PLAY WELL WITH OTHERS?
ABLE TO UNDERSTAND AND DO TESTING ON YOUR END?
TELL ME ANY MODIFICATIONS YOU HAVE DONE......EVEN NICE PICS FROM UNDER THE HOOD WOULD BE NICE
LAST QUESTION....THIS IS A DOOZIE!
DO YOU REALLY LOVE YOUR JEEP?
MEGA DETAIL IS APPRECIATED...HELPS ME A LOT!
THE MEDIC
Wednesday, September 26th, 2012 AT 8:18 PM
DMCAGLE
  • 6 POSTS
Obviously I know a little I fixed the issue. Ignition switch and coil went out
Saturday, September 29th, 2012 AT 7:46 AM
CJ MEDEVAC
  • 11,004 POSTS
THINK THE COIL COULDA BEEN THE WRONG TYPE?
SEE MY ANSWER ON DECEMBER 3rd, 2011 IN THIS POST
https://www.2carpros.com/questions/1982-jeep-cj7-ignition-problem-spark-distributor-cap
GLAD YOU GOT HIM SQUARED AWAY
THE MEDIC
Saturday, September 29th, 2012 AT 9:42 AM
DMCAGLE
  • 6 POSTS
Ehh doubt it was the wrong type it has been on there for the past ten years or so.
Sunday, September 30th, 2012 AT 4:57 PM
CJ MEDEVAC
  • 11,004 POSTS
SO ARE YOU FIXED. OR WANT MORE INPUT?
SEE-UNS HOW YOU JUMPED ONTO ANOTHER POST (WHICH WAS FINE BY ME). MORE INFO ON YOUR JEEP WOULD BE NICE
I'M JUST HERE TO ASSIST YOU. TELL ME MORE OF WHAT'S BEEN DONE
THE MEDIC
Sunday, September 30th, 2012 AT 7:05 PM
DMCAGLE
  • 6 POSTS
Thank you for your help im back on the road I'll try to upload some pics
Monday, October 1st, 2012 AT 11:56 AM
CJ MEDEVAC
  • 11,004 POSTS
NO PROBLEM
---I REALLY ENJOY HELPIN' OTHER CJ GUYS AND GALS. GIVES ME A WARM FUZZY WHEN I GET A THANKS (I USED TO BE LOST WITH THIS STUFF MYSELF)
WAITIN' ON YOUR PICS
POST 'EM HERE AT THIS POST
THE MEDIC
Wednesday, October 10th, 2012 AT 3:50 AM
DAVY KEITH
  • 33 POSTS
Hey CJ Medevac need some help with with my 1978 CJ7. Posted on another thread but will post here too in hopes of reaching you. No spark. It was running fine until a few days ago. I've spent two days doing diagnostics but still hitting a brick wall. Can fill you in on the details if I can reach you. Thanks!
Monday, November 28th, 2016 AT 5:28 PM
CJ MEDEVAC
  • 11,004 POSTS
Read the other post, I am here!
The Medic
Monday, November 28th, 2016 AT 5:38 PM
