BRAKES
DOUGWIL
  • JEEP CHEROKEE
I JUST REPLACED MY BRAKES IN MY 2002 JEEP GRAND CHEROKEE(67000 MILES). NOW WHEN I'M TRYING TO STOP I GET PULSATING BRAKING AND THE STEERING WHEEL SHAKES. I DIDN'T HAVE THIS PROBLEM BEFORE. ANY HELP!
Do you
have the same problem?
Sunday, December 10th, 2006 AT 9:35 PM
CARUNDELL
Hey doug,
Its very possible you got a defective rotor, but I would disassemble and double check your work and then look at the rotors carefully.
Regards,
Chris
Monday, December 11th, 2006 AT 10:55 AM
DOUGWIL
Hey doug,
Regards,
Chris[/quote:d4b2124a62] THANKS I'LL DOUBLE CHECK MY WORK.I'M ALSO THINKING IT MIGHT ALSO BE MY BACK BRAKES THAT ALSO NEED REPLACING. THE FRONT BRAKES MIGHT BE DOING ALL THE WORK. BUT I LOOK THANKS.
Monday, December 11th, 2006 AT 11:50 AM
LSUSSEL
This sounds like a case of rotar warpping. If you have the correct equimpment and tools resurface the rotor if its warpped, that should fix your problem
Tuesday, December 12th, 2006 AT 10:18 PM
JOHNBUKO
If the rotors are not stored properly, being stacked the wrong way, they can be warped before you ever put them on. Or you could have seriously overtightened your lug nuts. You should torque them at around 100 fpt.
Tuesday, December 12th, 2006 AT 11:24 PM
DOUGWIL
Thursday, December 14th, 2006 AT 9:11 PM
Recommended Guides
