2006 Jeep Cherokee Fog lights
ANDHOW91
  • 2006 JEEP CHEROKEE
  • 6 CYL
  • 52,360 MILES
I recently instaled fog lights on my Grand Cherokee. I replaced the indicator arm with a new one that has the fog light switch built in.I added the relay under the hood. I have power to the relay socket so that when I hard wire across the connectors the fog lights come on
With the relay in place (I have tried 2) the lights wont work at all
Any Ideas?
Do you
have the same problem?
Wednesday, May 19th, 2010 AT 4:47 PM
JACK42
Position 85 should turn to ground when light switch is turned on.Thisis what energizes the coil in the relay.When you plugged the new multi-switch in, did all of the wires match up properly? was there a mate for every wire in the new switch (vehicle harness has all necessary wires)
http://www.2carpros.com/forum/automotive_pictures/1639_jeep1_1.jpg
Thursday, May 20th, 2010 AT 8:29 AM
Recommended Guides
