1999 Jeep Cherokee high engine oil pressure
NBNJDEVILS
  • 1999 JEEP CHEROKEE
Engine Mechanical problem
1999 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
my jeep's oil pressure gauge will increase in pressure as I accelerate and decrease when I let off the gas petal. What is wrong
Do you
have the same problem?
Monday, March 2nd, 2009 AT 1:11 AM
VLADGEISER
Nothing, your oil pump is driven by the speed of the engine, as long as you are not completely losing pressure and are not lining out the pressure on the other end you are fine.
For example, my Audi S4 runs all the way to 5 bar, or 73 psi, when I floor the throttle, though it idles around 1.5 bar, or 22 psi. As a rule of thumb all you need is about 10 psi of pressure for every 1,000 rpm.
Wednesday, March 4th, 2009 AT 11:49 AM
Recommended Guides
